주요 콘텐츠로 건너뛰기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 달기
답변 3개
가장 유용한 답변
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Did you try updating controllers? It worked for me
이 답변이 도움이 되었나요?
점수 2
댓글 달기
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Falling Rose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 104
전체 시간: 7,356
