이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Have you tried another BT signal source device to prove whether the problem is with the phone or the speaker?
How far away from the phone is the BT speaker? BT usually only has an effective range of ~33' (10 Mtrs) depending on what may be in between the two devices e.g. concrete walls can limit the range
If the problem is with the phone and not the speaker, what is the make and model number of the phone?
Hi,
jayeff 의
