주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Slow and Laggy 2011 Mac Mini
My Mac Mini is quite slow and laggy. I have to experience a lot of spin wheels even for the simplest of tasks such as right-clicking to copy or paste something.
  • macOS 10.13.6
  • 2.3 GHz Intel Core i5
  • 5 GB 1333 MHz DDR3
  • Intel HD Graphics 3000 384 MB
I currently have 4 GB and 1 GB memory cards, however even with 2 x 4 GB cards I still experience the same problems.
It cannot handle more than 3 basic apps running at the same time. I usually have Safari, Mail, and the Music apps running all the time but if I decide to open anything else e.g. Photos, it becomes extremely slow forcing me to close one of the apps.
It also struggles with more than 6-7 Safari tabs depending on the webpages.
I often listen to a music playlist on YouTube and maybe after 15-17 songs, I have to close the tab and open a new one. It warns me about using significant energy and if I ignore it the device runs slow.
I am only using two extensions for Safari, Grammarly and AdGuard.
I am only performing the most basics of tasks on this device and it struggles to keep up with it.
I don’t want to buy another Mac, new or used. I am sure there is something that can be done to fix this issue.
I have these apps installed on my Mac which I believe are quite basic apps.
AdGuard for Safari, Android File Transfer, App Store, Automator, BitTorrent, Calculator, Calendar, Chess, Contacts, DaisyDisk, Dashboard, Dictionary, DVD Player, Express VPN, FaceTime, Font Book, GarageBand, Chrome, Grammarly, iBooks, Image Capture, iMovie, iMovie 9.0.8, Install OS X El Capitan, iPhoto, iTunes, Launchpad, Mail, Maps, Messages, Microsoft Silverlight, Mission Control, Notes, Numbers, Pages, Photo Booth, Photos, Preview, QuickTime Player, Reminders, Safari, Siri, Stickies, System Preferences, TextEdit, Time Machine, VLC,
Thank you for reading.
Cheers!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
What is your drive and its size? How full is it?
Also lets try running the onboard diagnostics restart your system and press the D key
Reference: Mac startup key combinations Let us know what you get for an error.
Thank you for your response.
500 GB SATA Disk, 250 GB used.
I ran the test and it returned with no errors.
I can constantly hear the device doing something. Definitely not the fan, maybe the drive?
댓글 달기
답변 2개
가장 유용한 답변
The real issue is the HDD over time gets fragmented. Getting a defragmentation app to undo the fragmentation or backup the drive fully and reformat it will also work.
Replacing your HDD with SSD is also a good direction or what I would do is add the SSD! Installing Mac mini Mid 2011 Dual Hard Drive Kit That way I can make the SSD be the boot drive with my apps and leave my stuff on the HDD. That way you don’t need as large a drive! A 250 GB would be more than enough for most people!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Oh Man! Just replace with the SDD and you are good to go.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes, I might just do that. I will upgrade the size too.
댓글 달기
귀하의 답변을 추가하세요
Abhishek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 11
전체 시간: 595
