Intermittent Circulation Pump Activity
I have a whirlpool du1100xtpt9 whose circulation pump had been deteriorating for years, it was obviously failing and was getting louder and louder until it finally died. I ordered and replaced the pump (WPW10757217) and it worked fine for about half a dozen loads. Then, when starting a cycle, the machine would fill with water, but the circulation pump would only make a faint humming sound without circulating any water. I was informed that its likely a blockage somewhere, but I checked both the interior drain and reseated the pump to check the connection there too. No blockage detected. I decided to run a test cycle to see what would happen and it ran perfectly fine. Once. Since then I’ve had the same results as before… washer fills with water, pump emits a faint hum, but does not circulate water.
Any ideas?
좋은 질문입니까?
Did you ever figure out the issue I’m having the same problem after installing the new pump and motor as well
mwhite082790 의
Sorry, no. I ended up getting a used oem pump off ebay and replaced the new production headache that was producing this issue. Still going strong
Mondian 의
