주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
20 질문 전체 보기
Charging paused - temperature too low
I’ve ordered a new NFC wireless charging coil plus the plastic plate that it’s attached to. I hope this fixes it. Does anybody know if it will?
It started happening after I put adhesive under the charging coil to keep it stuck on and also another part of the coil which doesn’t seem to connect to anything. I doubt I damaged the actual board; I hope not, it’s $100 used!!
The other part of the coil I’m referring to:
== Update (07/25/2020) SOLVED ==
Replacing the NFC Charging coil fixed it! Woohoo!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
NFC charging coil was the culprit!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Usually temperature issues are related to the temperature sensor on the Galaxies. If I’m not mistaken, it has pins underneath it that just make contact. If you don’t apply a little but of pressure or put the screws in around that area, it won’t communicate with the sensor.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Aaron Ortega 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 3,501
