Can you install the macOS Catalina Patcher with a hard drive
Can I install macOS Catalina patcher with a hard drive that is in a external bay or do I need a external hard drive or USB?
좋은 질문 입니까?
좋은 질문 입니까?
You really can’t run Catalina on this series. Its not worth the effort!
Remember this series can have limited RAM (2.26GHZ - 8 GB or 2.4 GHz - 16 GB). Also you can’t run older 16 or 32 bit apps which you likely have.
Lets say you had an i-series CPU for the sake of argument - Booting up your system, from which ever drive is controlled by using the Boot Manager by pressing the Option (⌥) key when you startup your system.
References:
해당 답변은 도움이 되었습니까?
You theoretically could run Catalina on this MacBook but I really wouldn’t advise you to. It still has a Core 2 Duo and it’s just not worth it to get Catalina on with faults when High Sierra works perfectly fine on these MacBooks.
I still use High Sierra unfortunately since that’s the maximum version my iMac supports, but chances are it’s still good for the next 5 years or so.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 539
