will not turn over, new battery and new fuses
mower will not turn over
좋은 질문 입니까?
Hi,
What is the model number of the mower?
Did you check that the pressure activated safety switch, which is located under the seat is OK? Raise the seat to find the switch which should have two wires connected to it.
This switch cuts the power to the engine so that it will stop and also not start if the operator is not sitting on the seat.
To bypass the safety switch until you get a replacement switch so that you can use the mower, disconnect the two wires from the switch, bare the ends of the wires and tightly twist the ends together and then insulate the bare ends with electrician’s tape, the mower should start when the ignition key is operated, without having to sit on the seat.
Be safety aware, a safety switch is there for a reason. replace it as soon as you can
해당 답변은 도움이 되었습니까?
Or Mabe need new spark plug or plugs
해당 답변은 도움이 되었습니까?
I dont know if That's a gas mower if it is mabe you have bad gas or water got into the gas tank or someone stole your gas or the fuel line or filter could be clogged..
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 82
