주요 콘텐츠로 건너뛰기
The B15 from Caterpillar is an Android based smartphone featuring a rugged, durable design and a fairly long battery life. Released in early-mid 2013, the B15 features a 4” LCD display, 2000 mAH Li-Ion battery, and ships with Android 4.1.
16 질문 전체 보기
Damaged front panel in CAT S60, how can I replace it?
Cracked CAT S60 front glass. Is my phone still waterproof when there is a cracked like this? And will the phone still be waterproof if i replace the glass? How to do it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Follow this disassembly guide.
It might still be waterproof, if the crack is only on the surface but better not test it ;)
Here are some screen kits for your phone. I don’t know where you live, you might even find a provider near you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Many thanks, I will check it :)
댓글 달기
It can be done, but you need some practice
CAT s60 Glass Only Digitizer Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Wieslav Sekulic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 168
