주요 콘텐츠로 건너뛰기
Apple 워치 시리즈 1은 2016년 9월 7일에 발표된 Apple Watch 오리지널의 개선 제품입니다. 대부분의 부품은 시리즈 2 와 동일합니다.
123 질문 전체 보기
isopropyl alcohol 90% replacement
Replacing my Apple Watch S1 screen. In the replacement instructions there are a couple places that says to use isopropyl alcohol 90% or better. Due to Covid-19 all the stores in my area don’t have any at this time. Is there a substitute I can use?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
IPA is mostly used to soften the adhesive. It doesn't help much
댓글 달기
답변 2개
가장 유용한 답변
The problem is you need something that will clean off the adhesive and not leave a film which messes up the fresh adhesive.
So your damed and double damed here ;-{
You can use ethanol but using it in a confined space can be dangerous both from the fumes and the risk of igniting the vapors! And you would need reagent quality which is also hard to find.
You’ll need to wait until you can find it or hunt it down - Sorry ;-{
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Dan for the straight forward answer. I'll have to keep calling our store each day to see if they get any in. Yep, I scrxxed for now.
댓글 달기
This might be a good time to mention that for electronics 99% isopropyl alcohol is safest and
for disinfectant 70% is most effective.
This web, though commercial, describes all the concentations and why best quite well.
https://blog.gotopac.com/2017/05/15/why-...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Michael Goebel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 278
