주요 콘텐츠로 건너뛰기
Repair guides and support for the Dell XPS 15", first released in October 2010.
20 질문 전체 보기
ESD protection when working inside laptop
I was wondering whether anybody can verify that this set up will work; I want to open up my laptop, but do so with ESD protection. I’m going to use an anti-static wrist strap which I’ll connect to an anti-static mat. I’ll work on top of this mat. As far as grounding the mat goes I’m open to suggestions. Currently I’m thinking of joining the alligator clip from the mat to the metal case of some appliance that’s already grounded. For example I have a toaster with a grounded metal body, that I could attach the alligator clip to and then plug into the wall with the outlet switch turned off. I’m in Australia, and I believe the ground connection will remain connected even if I turn the switch off at the outlet? I was wondering whether 1) this setup will effectively dissipate static charge to ground? and 2) if this seems a reasonable way to set things up with regards to both safety and convenience?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @jzq ,
My view is that the setup is OK. Also GPO power outlets in Australia only switch the Active lead. The Neutral and Earth connection are always there at the outlet. It may be easier to wire up a 240V plug with only the one wire (green/yellow) connected to the earth pin and put an alligator clip on it. Just a thought
Some things to check though.
a) connect the wrist strap to the earth connection on the mat and not just the mat itself to ensure a good earth connection for the wrist strap.
b) make sure that the wrist strap actually touches the skin.
c) depending on the age of the house wiring (or even if not that old), invest in a power point tester - example only to ensure that there is actually an earth at the power outlet.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Excellent, thank you for the help!
댓글 달기
답변을 추가하세요
John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 456
