Question about replacing internal Fusion hard drives
I have a question. I am currently running Catalina on my late 2013 27 inch iMac. My iMac has a fusion drive which has a 3TB HDD and a 128 PCle SSD. I bought a SSD that will replace my mechanical 3TB HHD, as well as a larger PCle SSD that will replace the 128GB SSD on the mother board.
I was told I don't need to do anything but replace both of these and I will be able to use either of the new ones for what ever I want and that they will both show up in disk utility and I can format them each separately and use either one or even use them both as separate boot drives with macOS on one and another macOS on another one. When I read this post I noticed that someone asked the question about splitting the fusion drive in order to be able to access both the new drives seperatly when the new ones are installed. Will I need to worry about this or am I good to remove them both and replace them both with new ones and be able to access both of them to use separately?
I was planning to clone my entire iMac to one of the new SSDs before I open up the iMac. Then replace the internal hard drives. I am not trying to create a fusion drive inside the imac when I replace both hard drives. I am only trying to replace them both and use them separately inside. My only concern is will I be able to access the PCle SSD once I install it? I know I will not have any problems accessing the regular SSD that replaces the mechanical HDD.
좋은 질문 입니까?
