Why does it smell like strong burning or gas
why does my car smell burning or like gas ?
좋은 질문입니까?
좋은 질문입니까?
maxinegarcia92 check for leaks inside the engine compartment as well as on the ground once you leave it standing for a while. Since you are not telling us when and if it always smells you also need to check if your engine runs rich which means it burns more fuel and can make it stink more. Again check for leaks first.
이 답변이 도움이 되었나요?
It could be a leaking exhaust system, or your fuel lines leaking. I would get a flashlight and look under the car for any obvious signs of leaking gas from the gas lines. For the exhaust, you can make soapy water(1 part dish soap to 30 parts water) and spray it on the exhaust pipe, especially near the exhaust manifold and other connections. Do this while the engine is running. Repairs are best done at a good auto shop.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 398
