Box fan makes zingzing sound
My Robeson box fan stopped working, meaning I could hear the motor hum but the blades did not rotate. I removed the blade assembly, cleaned out the dust and oiled the motor. I tested the fan without attaching the blades. The motor seemed to work. After I put the blades back on again, I hear a zing-zing sound. How can I fix this?
좋은 질문입니까?
댓글 2개
Hi @anupm12
If you hear the motor hum and it does not spin well, I suggest you to check on the fan capacitor first. It should not crack / bloat or leak.
Augustine 의
Augustine, after the cleaning and oiling the motor (with blades removed) does spin properly with no strange noises. When the blades are installed, the motor still spins but I hear a constant zing-zing sound. The capacitor is not cracked, bloated nor leaking.
Anup 의
