주요 콘텐츠로 건너뛰기
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
197 질문 전체 보기
Green and purple horizontal static
I have the 60” LE600DSS-V1, after I moved it to a new house (carefully in a vehicle by itself cushioned with blankets) I turned it on and it was a half green half red screens with a horizontal line and vertical line. I turned it off and on and then it was working fine. I plugged my laptop in through HDMI and after 2 minutes it flashed and went black. I turned it off and on and then got a screen with purple and green horizontal static. Now when I turn it on it just stays black and if I leave it it eventually goes back to the green/purple static. Anyone know what might cause this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
2 댓글
@oldturkey03 We took the back off checked all connections and everything looked good and clean and nothing loose, so we unplugged and reseated wires and checked a few other things. Decided to plug it back in and see and it was working fine. Gonna consider this a win lol
Tony, AWESOME! We consider that a win :-))
댓글 달기
답변 1개
가장 유용한 답변
Tony, it is possible that something came loose on the boards. You will have to remove the back cover from your TV and take a look at all the wiring etc. Pull the wires off and then reseat those. Check for any odd looking parts (burned, charred, missing etc.) and post some good pictures of all of your boards with your question, By doing so we can try to see what you see and may assist you identifying the cause for this.
Use this guide to add images to your QUESTION
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 143
전체 시간: 2,831
