주요 콘텐츠로 건너뛰기
Good airflow but no heat
Hello i have a 2016 Maytag dryer, model YMED3500FW0, (electric)
the heat stopped working a couple month ago, I called in an expert and he changed the fuse. 1 weeks later the heat stopped working again, the expert came in and changed the fuse and the high temperature thermostat at the same time. The dryer worked for about 1 month and then again the heat stopped working. I’m really desperate and don’t know what to do, the expert has no idea too. The airflow is really good and I take really good care of it. At the last visit the expert said that the heating element is good too.
please help me
Bonjour!
Alors tout d’abord la sécheuse que j’ai en se moment c’est une Maytag 2016, modèle YMED3500FW0, numéro de série M63404029.(électrique)
En faite tout a commencer il y a quelque mois lorsque la sécheuse a arrêter de produire de la chaleur, je me suis alors assurée que la ventilation circulait bien ainsi que le conduit ne soit pas boucher. Tout se passe bien de se cotée, aucun bouchon ou amas de feutre, rien de tout cela. J’ai ensuite appelé un réparateur afin qu’il règle mon problème. Il a tout d’abord changer le kit fuse car il semblait avoir sauté. Une semaine plus tard, le problème se reproduit. Il est alors venu et à changer encore le kit fuse ainsi que le thermostat. Tout allais bien pendant 2 mois et tout d’un coup encore plus de chaleur! S’il vous plais aider moi je suis désespéré
Merci beaucoup
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Does the fuse keep blowing? Which fuse are you referring to? The fuse located in the household power box or the fuse that is in the dryer (aka Hi Limit thermostat and thermal cutoff)?
If it is the Hi Limit thermostat in the dryer that is operating check that the dryer thermistor - part #42 Bulkhead parts is OK (aka the Internal Bias thermostat). The Hi Limit thermostat is only doing its’ job as it is a safety device in case this temperature thermostat isn’t working correctly.
The thermistor resistance decreases as the dryer temperature increases. Once the resistance is at the set value as determined by the temperature selected, the control panel will shut off the heat. As the temperature decreases and the resistance will now increase, that will allow the control panel to turn on the heat again to maintain an even temperature for drying.
If the thermistor is faulty and it doesn’t signal the control panel to turn off the heat when the temperature has been reached then the temperature will continue to rise until the safety Hi Limit thermostat operates to prevent a fire from happening etc.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sabrinayounan1997 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 119
