Replace the paste on the GPU on the iMac Intel 17"
Which one of the two heat sinks has the GPU underneath it?
Should I reapply the thermal compound on both heat sinks while I'm at it?
좋은 질문 입니까?
좋은 질문 입니까?
I would use the CPU fan replacement guide to point to which one is for the CPU. That guide is here. Personally if you are having heat issues I would reapply thermal compound/paste to both the GPU & CPU. You do not apply thermal compound/paste to the heat sink, it is applied to the processor - thin as possible, yet still covering. A rough guide for applying thermal compound is here. I recommend using the Arctic silver thermal compound/paste available here.
안내서
난이도:
운영
5 - 20 minutes
안내서
난이도:
어려움
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 1,860
