주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
Using the original screen
I have the dreaded hot batteries that has caused the screen to delaminate from the frame. There is quite a separation on the right hand side ``
``and a smaller on on the left hand side
of the screen. There is very little discoloration on the screen and there is no flicker.
It is out of warranty and Microsoft will swap me a “similar” refurbished Pro 5 for $599.
Question: Assuming I can detach the screen with no damage, can it be reused (or did the heat causing the delamination stretch it, too)?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@tigershark125 going by your description it appears that this is “only” a delamination. IT won’t have stretched it so you can reuse it. You may even find that some sort of adhesive (OCA/LOCA) could minimize the effect of the delamination. Post some images of what you are looking at, with your QUESTION. That way we can see what you see. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Added pics and thank you
uioe the delamination. Makes me wonder why. Anyhow I'd proceed with a very careful attempt of removal and the relaminated with some have duty UV adhesive.
댓글 달기
답변을 추가하세요
Walter Peycha 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 89
