주요 콘텐츠로 건너뛰기
A 15.6" laptop by Lenovo from 2013.
Memory test failure, fix and some questions
Overnight my B590 developed a memory fault.
On boot up, a single long beep, and the machine would drop into the bios. Upon running the inbuilt memory diagnostics, I found that values being written during the test were coming back with a single bit always set to 1.
Did usual reseating of the DIMM, changed the DIMM location, swapped the DIMM with a new module. Same error, indicating that this was probably a motherboard issue.
Ran memtest86 (4 passes) from a USB drive with no errors. On rebooting, Windows started up as usual.
Q1: Why did this work? I can only speculate the memtest somehow cleared the stuck bit on the motherboard. Bad capacitor?
Q2: Is this problem likely to resurface?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I would just wait and see.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hello, my theory behind this issue is dust in the first place, and by changing and replacing the DIMMs you had to move your laptop upside-down multiple times which might cleared the dust and the memtest86 was just a lucky step.
If this happen again, don’t move your computer, try to run it normally multiple times to make sure the problem happen at 100% and then run a memory test, if it works then it’s a software issue if not then it’s a hardware.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Sanjay Mehta 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 33
전체 시간: 2,825
