주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 Amazon에서 출시한 고급형 Fire OS 5 태블릿입니다. 10.1인치 HD 디스플레이와 MediaTek 쿼드코어 프로세서를 탑재했습니다.
The picture is very dark.
How do I lighten the screen?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
I, too, have this problem. I turned Alexa off and there was an immediate “fix”! Sadly, Fire wants you to have Alexa and it was turned back on. I am perplexed at how to fix it permanently!!
의
Same problem. Steaming doesn’t give the option to brighten picture. Only in HDMI inputs
의
댓글 달기
답변 1개
선택된 해법
pblr58  depends on how dark dark is. you of course checked your settings
  1. Swipe the status bar down to open the Settings drawer.
  2. Tap Brightness.
  3. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
  4. Auto brightness must be off.
  5. If that does not work then the issue is most likely the backlight inside your screen. You would have to replace the LCD display for hat. Worst case scenario would be a failed backlight circuitry on your main circuit board.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Tried all kinds of tricks with no luck. Then duh!!! You simple,easy,obvious quick fix, well praise to you and yours!!!
의
댓글 달기
답변을 추가하세요
pblr58 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 74
전체 시간: 38,202
