주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
135 질문 전체 보기
iPhone freezing after screen replacement
I replaced the Digitizer on an iPhone 11 Pro Max and it seemed to work fine during testing. The customer called a couple hours later saying the phone is freezing. It works fine after a hard reset but only for about an hour then freezes up again. Any suggestions? Could it be the aftermarket LCD I installed?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It could be a bad screen or perhaps something went wrong during the repair. Obviously, you should take a closer look to see if any of the flexes are damaged or if any components were damaged or dislodged near the relevant connectors.
As a repair shop, you probably have other screens so I would try one of those first. If you still have the customers original screen and it is functional, try that one too.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Kenny G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 57
전체 시간: 1,145
