no airflow in fridge, great airflow in freezer
my freezer works but my fridge does not. i disassembled the unit and had frost. the evap fan was spinning but there was no airflow. thinking it’s the defrost circuit i defrosted the whole unit. i reassembled the unit. in the freezer the fan spun and i had air flow. but no flow into the fridge below. i made sure the vent was open and unobstructed. still no airflow. if i open the freezer door there’s great airflow into the fridge i close it and it goes away completely. i can’t find anything like a vent that may me obstructed. i made sure the condenser fan/coils were clear. i know air has to flow in a circle. any ideas?
좋은 질문 입니까?
댓글 2개
Hi @bigbadogre12,
What is the model number of the refrigerator?
If the doors have a door switch that is accessible i.e. can be seen in the door jamb and is not a hidden magnetic door switch, that turns off the light, try manually operating the door switch with the door open.
This should turn off the light but turn on the evaporator fan in the freezer compartment. Make sure that the other door is closed as either door when open will stop the fan.
jayeff 의
maytag MTB1981ARW (which is supposedly made by whirlpool) . the fan works when either door is open. the fans run as they should there’s just no air movement. i know there has to be a air return issue.
jason 의
