주요 콘텐츠로 건너뛰기
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
Why is the sound garbled when first turned on
sound is going thru speakers and when first turned on then as TV warms up sound clears however taking longer to clear each day. What do I need to do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
dorann.cafaro  appears to be an issue with your audio IC located on your main board. Post some good pictures of your boards with your question so that we can see what you see.
기존 질문에 이미지 추가하기
You also want to try all different input sources and see if that changes anything as well as trying to connect a sound board or external speaker. Let us now what you find out. Please verify that your TV is a Samsung LA40R81BD 40in LCD TV
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
sorry but I don't know where or what the main board is? I did mention that we are connected to sound system outside TV
@dorann.cafaro what happens when you disconnect the sound system and just listen to the TV speaker?
댓글 달기
답변을 추가하세요
dorann.cafaro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 156
