주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
iPhone battery not showing after replacement, plus one more
After replacing my battery, it was working fine for weeks. But suddenly, my phone started rebooting with the battery percent not showing and the battery indicator being red and low at the beginning of the restart. After that, my phone works fine. Once i opened it back up and re-seated the battery cables the battery percentage never came back and the phone acts like it’s nearly dead, despite the near 100% charge on the phone. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
선택된 해법
There are some tiny components next to the battery connector that allow the battery to communicate with the CPU about charge level. When these are accidentally dislodged during a repair, it will cause these exact symptoms.
I would open up the phone and closely inspect this area because they may have been partially damaged or dislodged during the repair and only came fully disconnected recently following a drop, for example.
Check the components highlighted in red in the picture below.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
From what i'm able to see with my bare eye, i dont see anything where R3201 should be. Is there supposed to be something there? And if so are there ways i can get it replaced or fixed?
It should definitely be there. Bare eyes may not suffice, especially if you're no longer 25 years old ;-). Use a magnifying lens or jeweller's loupe (or your camera zoom) to see if it is there or not.
댓글 달기
I am having the same issue with 5 times magnifier i dont see any components that are missing. any other possible issues
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ray McDonald 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 2,131
