Replaced my battery, however, all LED lights are now illuminated
After some quick diagnostics resulting from a battery that would no longer charge (flashing red power LED) when charging adapter connected, I figured the battery was shot and would no longer charge as the voltage was likely below the system threshold.
After installing a new battery ordered from ifixit, all of the LED lights come on. When I plug in the power adapter, the battery does not appear to be charging and ll light remain illuminated until I remove the battery.
좋은 질문 입니까?
댓글 2개
@codyandresen have you double checked your work? Everything properly connected? Wiring looks okay etc.?
oldturkey03 의
All work has been checked and properly connected. I'm wondering if this issue is due to a malfunction with a component on the PCB?
Cody Andresen 의
