주요 콘텐츠로 건너뛰기
Model A1318 / 32 or 64 GB capacity
299 질문 전체 보기
iPod touch 3g can only use with wall charger.
hi guys i have an ipod touch 3rd gen and i can only turn on when i connect to the wall charger and if i disconnect its turn off and the other thing that he make is that when im using whit the wall charger appears the button that say slide to power off or if he dont say this he make like i put to sleep and the i need to hit the home button to slide to unlock and he does alot of time so i think that the battery is bad and i dont know if the power or sleep button is bad soy can help me please? thanks...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
gmaincomputerservice, I'd start with the battery first. The reason why you can't start it any other way is because the battery does not hold a charge the way it should. The AC charger supplies more amperage to the iPod. start with the battery, then reevaluate for other damage. It is my experience that be trying to fix more than one thing at the time, the trouble shooting gets confusing..Good Luck and let us know how it is going.
iPod touch (3rd Gen) Battery
iPod Touch 3rd Generation Battery Replacement
iPod touch (3rd Gen) Battery 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
gmaincomputerservice 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,384
