Screen uniformly dim. Briefly got back to normal then happened again
My 60uj6050 lg tv’s screen got very dark one day. Tried all recommended settings,even factory reset the tv. Didn’t help. But then, a few hours later we turned it on, and it was fine. A few days later, the problem came back, this time for good.
Here’s the information:
- no amount of fiddling with settings helped
- Screen is dark, not black. No need for flashlight
- picture is uniformly dim. No stripes, no halves, or spots
- Bought a power supply board and motherboard from shopjimmy. The parts that I got didn’t look like new parts. Neither fixed the problem.
Before buying backllight strips as the next logical step, I have doubts. Based on what I understand, uniformly dark but not black screen is more likely to be caused by power supply. Could it be that shopjimmy sold me parts pulled from broken units, and the one I got was broken? Or does it sound like a clear case of burnt backlight? What do you make of the fact that picture briefly returned to normal before going bad again?
The last question might point to the diagnosis.
좋은 질문 입니까?
댓글 2개
I have the same issue. It started months ago and performing a picture test would bring the brightness back to normal- did this four or five times over a period of 6 months or more and it seemed to be when the TV was first turned on. Today this would not fix it. I reset the AV and adjusting brightness from 50-100 had no effect on the picture. The picture is still there but very dim, like 10-15% of normal.
James Dietzel 의
@James Dietzel what model is your TV and what voltages do you have going to the backlight LED's from the power board?
oldturkey03 의
