주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
What thermal paste to use after bottom board swap?
Hi guys,
Last night I did a bottom board swap on iPhone X (tried it for the first time and succeeded, very proud of myself :D). After I soldered both logic boards back together I have realised there is no thermal compound inside anymore. I want to do my repairs to the highest possible standards, so I think it's a good idea to apply some thermal paste back where it should be.
My question is what product do you use for it? What type of paste?
Thanks,
Marcin
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
If you are going to put thermal paste back on the CPU than Artic silver will be fine. Although I think it would be a waste of time and money as thermal paste will only dissipate the heat when underneath a heatsink. But that is just my opinion.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
IMO, Apple uses a special thermal paste based on Carbon Black. I agree with Chris however, Arctic Silver is fine if you want to go that route.
I have used noctua nt-h1, never used it on a phone though. I use it for computers and devices of the sorts
I only use it cuz it is a lot cheaper and seems to do the trick from a reputable cooling brand
댓글 달기
There is no thermal paste on the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
https://prnt.sc/v88lcc
https://prnt.sc/v88lvc
so what is that substance on BB_CPU?
댓글 달기
i did a iPhone X lower board swap, i transferred the Wifi, baseband,eeprom and nfc chip. All was working fine. But once i did iOS Restore, my wifi and bluetooth greyed out. Wifi Address under settings show “N/A”. I need help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marcin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 393
