Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
좋은 질문 입니까?
좋은 질문 입니까?
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 5,001
댓글 1개
Thank you for accepting my answer and good luck to you.
oldturkey03 의
