Removing the BIOS asset tag from a used Dell?
I know this may be a bit exotic for the iFixit community and that's fine. I purchased 2 E7440 i7 FHD Touch systems as a lot for almost nothing compared to what they get complete, so I took a chance and both were easily repaired - even if it took a new drive (pulled), spare RAM and 2 LCDs (1 with TAB issues, other from a junk system that was too far gone - fried inductor and dead shorted motherboard). I’ve blurred the tags to protect the previous company if anyone knows.
PART 1: I noticed this because I needed to confirm the tag on the bottom matched for the ownership transfer (otherwise I remove the sticker, and replace or leave blank) so I decided to make sure it's not hiding an asset tag while I was there after it passed the tester hard drive check (shows in BIOS).
PART 2: When I checked for anything I want to change in the BIOS before I install Windows, I did go though the BIOS to see if I need/want to adjust anything and they have a BIOS asset tag. The issue with Dell is you can’t clear this out in the BIOS once set (although it can be set in BIOS) and it persists. I did some research and I think I know what tools I need to use, but I’m not 100% clear. It looks like a job for CCTK (Dell Command|Configure) on the E7440, since it’s such a new machine that may not work with the legacy Platform Tag Utility.
Is there any instructions on how to do it I should be aware of, and which one will clear it out? Normally I’d know this, but you do not run into this every day.
좋은 질문 입니까?
댓글 3개
Hi Nick, Have you tried this Dell utility?
https://www.dell.com/support/home/en-nz/...
I got this from:
https://www.dell.com/community/Laptops-G...
Let us know how it goes.
mike 의
@aactech Why would someone leave an asset tag in the BIOS like this? If you know how to add it, you can remove it. Granted I didn't know because this is a first time issue for me to the extent I needed some clues, though.
I mean sure they're old but these have the i7 CPU - they're worth rebuilding if you're equipped.
They were sold as no boot systems though.
Nick 의
@aactech Didn't work - permission denied when I fed it one of the tags from the E7440s :(.
Nick 의
