panasonic rq-5w33v tape not working
Panasonic RQ-W33V tape not working
좋은 질문 입니까?
Hi @ldavinci
I cannot find anything on your model using either number that you posted.
The best that I can suggest is that you may have to contact the supplier in this link if it turns out that a broken rubber drive belt is the cause of the problem.
You may have to open the player and check to find out if it is OK or not.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 27
댓글 2개
Hi @ldavinci ,
Please verify the model number of the device as searching for the number that you posted gives no results.
Is the tape turning or not i.e. play, FF, REW etc?
If not it may be a broken drive belt.
jayeff 의
The tape is not turning is any of the options, I believe the Model number is: BCOCA97142.
Angelo Basile 의
