주요 콘텐츠로 건너뛰기
A mid-range smartphone from Samsung released in 2019.
99 질문 전체 보기
Will device boot with no battery?
Hey, i was taking a look at a phone for someone who said it wont charge or turn on.
When plugged in a lighting bolt in a circle appears but no battery percentage. i took apart the phone and disconnected the battery then plugged in the charger and same thing
Lighting bolt in a circle with no battery percentage
Does this mean the battery is the problem? The device in theory should boot without one while plugged in like a laptop.
Would this mean the issue is software and not hardware since the charging port is working.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Austin Sidman this “ i took apart the phone and disconnected the battery then plugged in the charger and same thing. Lighting bolt in a circle with no battery percentage” makes the battery the prime suspect. Replace the battery then re-evaluate. There are multiple other board level hardware issues that could cause this but start in an orderly fashion so as to not try to change/repair parts that don’t need to be replaced/fixed.
Samsung Galaxy A50 Battery Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It could be software related, but to me it rather sounds like a problem with the part of the circuit that charges the phone (or the battery itself).
It is with some phones possible to boot without a battery depending on the amount of power the phone consumes, and the chargers ability to provide this power.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Austin Sidman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 1,262
