주요 콘텐츠로 건너뛰기
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
26 질문 전체 보기
"contact service" problem in Nokia 5130Xpress music
Hi.........
I am suresh
I am facing a problem in my Nokia 5130 Xpress music fone.
When I turn on my phone it is asking for flight query (as i turned on that feature).
If i press "Yes" It is diaplaying "Contact service" and not proceeding furthur
If i press "No" It is diaplaying "Contact service" and is going off immediately.
Pls help to solve this prob....
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개:
please sir
how can solve contect service problem
== Update ==
hi sir
contact servics peas ok and of
== Update ==
contact service peas ok of
댓글 달기
답변 3개
Here is an answer to this old question. It would help if you looked through the solutions section of this device. Here is my answer from a previous question that deals with the same issue :" you could try to reset your phone
http://en.kioskea.net/faq/470-how-to-res...
1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345
2. *#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)
3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons
http://discussions.europe.nokia.com/t5/O...
If none of this works you can also try to update your firmware. Download and install the latest Nokia Software Update and Nokia PC Suite, connect your phone, and run NSU. You will be prompted to update the firmware if a new version is available. Just make sure that you backup your phone since it will delete everything in th memory of your phone.
And if none of that works, you should definitely contact your cell service provider. Did you pay your bill :-)?" Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
SUPERDONGLE or SIMLOCK area problem. You need to calculate RPL for your phone (not for free) and flash it with one of boxes (mx-key for example).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
nokia xpressMusic
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Suresh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 2,549
