My iPod went through washing machine. Won't play.
Following iFixit directions, I’ve started disassembling it. Previously, when I plugged it into the Air USB port, its contents were readable and replaceable. But when I install new songs/synch, it won’t play. I’m not sure but does not seem to take a charge. New battery? Logic board? Both?
좋은 질문 입니까?
댓글 6개
Yeah a good guess would be the battery
Did you open and clean the thing with 99% alcohol
Tsar_ Bomba 의
Thanks for your advice! I buried it in rice for 5 days. Have not cleaned it with anything. Not sure how to do it with alcohol. Brush it gently? Soak it? Anyway, 99% is not available here. Only 91%. Please advise further. Much appreciated!
Chuck Schroeder 의
Um... brush it. I don’t know if 91% will work but is it high quality? It’s all about preventing accidental links between circuits. 99% alcohol means that there should be less impurities to be left behind, causing unwanted linking and shorting.
Tsar_ Bomba 의
Don't know about "quality". It's standard rubbing alcohol from a pharmacy. If you thing it will do more harm than good I'll order from Amazon.
Again, thanks for you advice!
Chuck Schroeder 의
If it’s really value to you, don’t take chances, if it’s not, then 91% will probably work
Tsar_ Bomba 의
댓글 1개 더보기
