주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
NFC and apple pay problems
Just a quick question. Recently repaired the back glass of 11 however damaged the wireless charging coil. Ordered a new one and installed. Now Apple pay is not working so NFC is not working either. I just wanted to know if the coil is the NFC problem? Or is it the flex cable at the top of the phone that’s the problem? Thanks
Update (11/17/2020)
Any idea which one it is? There are 3 connectors coming from 3 different antennas at the top. I have highlighted them
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
After reconnecting all 3 of the connectors shown in the screenshot the NFC function worked. I still don't know which one of these was the problem but it seems that the connection was not passing the signal through. For anyone wondering how to test NFC I use NFC tags which I write to using a compatible phone and then just tap the top of the phones to see if the tag gets picked up.
Hello ! im having the same issue after change the back chasis, and apparently the nfc antenna is well installed, i dont know how to fix it.
Hello! I'm having the same issue after changing the full frame, and apparently, the NFC is not reading or even functional via Apple Pay. He broke my volume flex cable and told me that he will replace it as soon as he got stocks, I didn't bother to come back to him since he is far away from my place. I fully replaced the volume flex cable and got it to working. I thought this will fix the NFC problem, but it didn't. So, what is the other possible issue with this? Should I replace/try to reseat the Bluetooth antennas, but my Bluetooth is still working. Or should I replace the NFC coil for like the wireless charging for the back glass since its probably broken also since I can't use it also. Help me find a solution to this please.
@sergiorp Hello have you solve the problem?
댓글 달기
답변 2개
선택된 해법
It’s at the top of the phone, usually around the camera.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
I have updated the question highlighting the antennas. Any idea which one of them it is?
@iphonerepairtom were u able to figure out which antenna it was?
@picklefixesstuf Commenting as a separate answer so I can attach pictures.
댓글 달기
The NFC antenna is frequently mislabeled as Bluetooth on vendor sites. It is generally mounted between the camera module and the housing.
It's difficult to find pictures of it in place due its positioning in the housing, but it's this one mounted into the side of the chassis here. It is the one with the screw on the inside of the camera cutout. In nearly all iPhones it will use the standoff which goes into the board near the camera as a grounding point.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Alright. Thats the one I thought, I inspected that antenna last noght and it looked completely fine. I have also been told on other forums that the NFC is located in the charging coil, but im still not sure. I will just have to check both I guess. Thank you for your help
After testing I can confirm that it is the antenna u r referring to. Sorry for doubting u, I appreciate the help. Thank you
@picklefixesstuf No offense taken. There is a lot of misinformation surrounding those peripheral parts because Apple does not communicate that sort of thing, which means it's up to repair community to figure out what's what. Also I think it sort of makes logic sense for NFC to be tied into the charge coil. Nevertheless. Glad you got that sorted out!
My Apple Pay has stopped working after changing the housing , does the antenna mentioned here have something to do with it ?
댓글 달기
답변을 추가하세요
Tom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 41
지난 30일: 206
전체 시간: 13,294
