주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
질문 마감됨
Where is the cmos battery?
I have a liquid damaged 2007 macbook 2.1 GHZ (A1181) that's working fine but isn't charging the battery.
I swapped out the DC in board and battery connector with known working parts but the issue remains.
I tried an SMC reset several times but to no avail.
I decided to disassemble it to clean up the logic board (there was some corrosion on some areas) but when I took it out and turned it round to remove the cmos battery there wasn't one. I assumed it was removed and not replaced as the macbook had clearly been opened before, but I couldn't find the jack for it.
Here's the type of logic board: http://www.techex.biz/ebaybiz/pics/Mothe...
This is the one I've seen before, where the cmos battery is placed in the middle of the board:
http://67.19.154.220/HQ/apple_macbook_a1...
Where is the cmos battery to be connected on this logic board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It sounds like you have the Santa Rosa or Penryn version of the MacBook which has a slightly different location than earlier models. Here is the guide showing the location.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Matt! Not calling it the "PRAM Battery" was obviously the downfall of my fruitless searching.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 10,901
