주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
Will a Display replacement fix this?
Hello,
A while ago I fell longboarding with my phone in my pocket. At first there was a hairline crack that went up and down the screen. Over time it appeared the crack was spreading and it became a back blob.
If I take my otterbox case off I can see what is on the screen where the black blob is. In light I can see the whole screen, it just looks like the backlight isn't working where the black blob is.
The front glass is fine, the only damage is to the internal display.
My question is what do I need to fix this, I'm not sure if it's a backlight problem or if it's a cracked lcd screen. Would a Display Assembly kit fix this, it appears to be the easiest way to fix my problem.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Is this on the digitizer or display? If it's on the digitizer, you can replace this part as a single piece on the 3GS. It isn't like the 4 where you buy the whole thing.
iPhone 3GS Front Panel Assembly Replacement
If you broke your display then you need the LCD. You can buy the unit as a whole, or just the panel. I would buy the unit at this point, since it costs about as much as a LCD only anyway.
iPhone 3GS Display Assembly Replacement
iPhone 3GS Display Assembly 이미지
안내서
난이도:
조정
15 minutes
iPhone 3GS Front Panel Assembly 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Scott White 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 370
