주요 콘텐츠로 건너뛰기
My touch screen is no longer working after a technician "fixed" the tr
A technician came to fix my laptop after the Trackpad was wobbly and installed a new Trackpad add which has a piece of plastic sticking out of it so I need to fix that or remove it but also now the touch screen does not work I was wondering if it is as simple as a cable that is not being plugged in
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @fisherofbags ,
Check that the touchscreen has not been accidentally disabled in BIOS.
To enter BIOS shutdown the laptop in the normal manner and then restart it and press the F2 key immediately after the laptop starts.
Once in BIOS go to Table 8 System Setup Options - Display Menu > Touchscreen and check that it is enabled. According to the service manual (see p.61) the touchscreen will always work in BIOS irrespective of this setting.
If it isn’t disabled and it works OK in BIOS, check the touchscreen in Device Manager (not sure where it is located but maybe check in Device Manager > Human Interface Devices or > Mice and other pointing devices to check that it is installed OK by the OS.
Not sure that it would be a loose cable as it appears that there is only the display cable between the motherboard and the display so I think that the touchscreen wires would be in it and it would be unusual for only the touchscreen to be affected and not some parts of the screen as well.
The manual shows how to gain access to the display and the touchpad so hopefully this is of some help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
cheers bro, you fixed that quick! it was a bios issue!
댓글 달기
귀하의 답변을 추가하세요
John the fish 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 78
전체 시간: 1,821
