주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
Screen wont turn on after a screw got pinched in display
Screen wont turn on after a screw got pinched in display, but the device still turns on like u can hear it but it wont turn on screen wise, this was after a replacement screen, so i tested the original screen again to make sure i didnt fry anything and the original screen still works, can really a little dent prevent the screen from turning on. heres a picture of the damage
Update (12/05/2020)
its a 2017 macbook pro 13inch'
@oldturkey03
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
anyone have any ideas
@zmentz your MBP a A1708/EMC 3164 or a A1706 / EMC 3071? We need to know this so we can identify to right components for you. Do you have your logic board out? If so post some good top and bottom pictures of it with your QUESTION. 기존 질문에 이미지 추가하기
@oldturkey03 ok will do, one question also is the backlight fuse on the bottom or top and its also the a1708, and i will send the pictures tomorrow because im currently not in work today
댓글 달기
답변 1개
가장 유용한 답변
@zmentz it all depends on where it got damaged and what parts got shorted out. Size of the damage does not matter, location most certainly does. Since your old screen works etc. it is definitely your display that got shorted out.
Update (12/09/2020)
@zmentz it’s on the top site. The fuse is a 3Amp 32Volt fuse in a 0603 package.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
now all the sudden the original one wont work now, i dunno what happened
@zmentz now it gets interesting. What happens now? Your MBP comes on? Checked the backlight? What exact model/year etc.is your MBP
2017 13" macbook pro
@oldturkey03 so i want to check the backlight fuse becasue i was mistaken and it is not working because if i shine a light into the back of the screen i get a display so is the fuse on the top or bottom of the board?
댓글 달기
귀하의 답변을 추가하세요
Zach Mentz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 81
