주요 콘텐츠로 건너뛰기
Laptop will not power on
I replace the screen and everything was working fine. I noticed the track pad was a little sticky so I powered down and had to remove the internal battery to fix the track pad. Once I reassembled everything it is totally dead. No lights even when the charger is connected. I have taken it back apart and check for any loose connections. I have removed and reseated the RAM. I have tried to run off of ac power only with the battery removed but it is still completely dead. I have also tried a har reset with the battery out pressing the power button for 60 seconds and then going back and trying it all again.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Justin,
All I can suggest is reviewing your assembling. Check that all cables are correctly oriented. What else could it be. Please,you did disconnect the battery before doing anything, right?
Service manual:
https://support.hp.com/nz-en/product/hp-...
Good luck.
Mike
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Justin Sousa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 215
