주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
176 질문 전체 보기
Need to know different chips one logic board
Bought this IMAC broken and am trying to fix it. It looks like a couple of chips are cracked and or broken off on the logic board. If anyone could tell me what exactly these things are and possible where I could find some new ones to solder on.
Thank you,
David
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
@dclnine - You'll need to find the board number so we can try to find the correct schematic and board view to figure out what you've damaged.
From what I see I suspect you have damaged inductors as part of the Ethernet port. Without looking them up I can't tell you the values.
I believe the board number is 820-00629-A. If thats not the right number please let me know and I can try to find a different one.
댓글 달기
답변 2개
선택된 답변
Sorry I don’t have the needed drawings you’ll need to get it your self 21.5" iMac A1418, 820-00597-A BoardView, Schematic
해당 답변은 도움이 되었습니까?
점수 0
댓글 10개:
Got the schematic thanks for pointing me in the right direction. Im not really that great at reading these things but it says one of them is t4000 and im still trying to find the other one. If I sent you a copy of the schematic would you be able to help me decipher it? Also I can give you my email so we can communicate that way.
@dclnine - If you want post the two files I'll take a look.
Look at my info card for my email address
Sent an email your way.
@dclnine - check to see if it bounced, did you use the underscore?
I did use the underscore.
댓글 5개 더보기
댓글 달기
가장 유용한 답변
@dclnine you are correct. One is T4000 and the other one is T4025. Both of those parts are LC607-AP-AFT453220M-171-T001 pulse transformers made by TDK. Sorry datasheets etc. no easily found.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the reply. Any chance you know where I can find one of these logic boards for not a ridiculous price?
댓글 달기
귀하의 답변을 추가하세요
David Laird 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 387
