주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2, 2.26, 2.53, 또는 2.66 GHz Core 2 Duo 프로세서는 DDR3 RAM을 사용하며, 그래픽 프로세서는 설치된 시스템 RAM에 따라 128-256MB VRAM을 탑재한 FX9400입니다.
Won't Boot into Windows After Partition Resize
Yesterday, I was using my mac mini in windows, and was downloading, and copying some Disk images, and windows started giving me messages telling me that the disk space was low. When i created the partition, i set it for 15GB. since the drive is only 120GB with 70GB free. I decided to resize the disk, by creating an image of the disk, (in disk utility, and then used the boot camp utility to remove the partition. I then used it to create a larger partition (30GB) and then used disk utility to restore the drive from that image. It did, and after about 1 hour, it was done. I then went to startup disk, and selected "Windows" on BOOTCAMP (My Windows Drive) and rebooted it. After about 5 minuted of a black screen with a blinking white underscore, i rebooted it, held option, and it gave me a list of boot drives, and the "BOOTCAMP" wasn't one of them. I tried reseting the PRAM, PMU, and a lot of other things, but no success.
Any Ideas?
Thanks
Also, it was running Windows XP Professional SP3
And had the FAT Filesystem
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
I'm guessing it was a formatting issue. See, Mac OS creates FAT partitions, but windows likes NTFS, and usually that's what you have to reformat to in the installer. So it's possible you tried to restore an NTFS image to a FAT image, which could result in corruption and stuff. Hopefully you had a backup. I hear there's a tool called Wincloner or something like that which helps with this stuff. Great for quick resizes I hear.
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
unfortionatly, it's too late for me to use winclone, i already imaged the drive, and erased it, and winclone will only restore if it created the image. any other ideas?
의
Do you have that original image? Or maybe you can try mounting the image you already have separately. Or running any recovery tools on it.
의
I have the image, on the Mac OS Partition of my mac mini, when i restore it to the bootcamp partition, it works, and the startup disk finds it, but under the info, it says "Bootable: No" and the mac can't boot of of it, and disk utility can only restore the disk from that image. I can mount the disk in mac os, but you can't boot of of somthing like that. Also, converting it From DMG to ISO didn't help either.
의
What format is the image?
의
It is a DMG, but i just decided to install Windows 7 Pro on it, and copy files off of the dmg.
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Chris Green 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 6,787
