Speed only works on highest setting on the dial
Hi my Kenwood mixer will only work at the fasted setting on the dial
Update (12/18/2020)
- On the fastest setting on the dial
좋은 질문입니까?
좋은 질문입니까?
@freddifrog this is most likely caused by a failed spark suppression capacitor for the governor. IF it fails your mixer will only work at full speed. Check for it under the cover on the bottom of the motor. You’d be looking for a small, round, aluminum can looking part. Post some images of what you find so we can assist you further with that.
Here is Untitled the service manual to help you with your disassembly etc.
이 답변이 도움이 되었나요?
there are two aluminum can looking parts but how do I know which one works and how can I replace it and where can I get the part?
There's sure to be a label on it. Post a photo here, we will help. Replace both, they're cheap. You can usually get them through an mail order company for electronics.
I had the problem on kcc9060. I changed the dial element (so the triac) and i solved the problem.
이 답변이 도움이 되었나요?
The problem returned its not the dial maybe the motore rotation sensor
지난 24시간: 1
지난 7일: 2
지난 30일: 29
전체 시간: 1,060
댓글 9개
Can't find an option to add a photo
P Greenwood 의
@freddifrog here is the guide for it. 기존 질문에 이미지 추가하기 You'll have to edit your QUESTION and add those images to it.
oldturkey03 의
Thanks. Just having a look.at it now
P Greenwood 의
Apparently I need a part
P Greenwood 의
I need a part BTA208-600B
P Greenwood 의
댓글 4개 더보기
