주요 콘텐츠로 건너뛰기
The Nikon D40 was released in 2006 as an entry level DSLR.
SD card jammed in backwards. What now?
I gifted my Nikon D40 body and lenses to my kid, who promptly put the SD card in backwards, and now it won’t budge. Let’s assume the slot is fine and will work if the card is extracted. Is anything less than a total breakdown possible? I learned not to just unscrew things willy nilly with these cameras a long time ago. Any resources on play by play to attempt this? Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi
There is a tutorial on iFixit on how to remove the motherboard: Nikon D40 Mainboard Replacement
Unfortunately, taking out the motherboard does require desoldering, but other than this it’s a pretty painless process. You will not need to tear down the entire camera.
Before replacing the card reader, you can try to carefully bend the pins back to their original shape.
Still, i’m inclined to believe that all will be fine once you’ll get the card out.
To prevent further damage to the reader, do not use excessive force and make sure you only grip the card and not the slot itself.
Cheers!
Bogdan
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brad Patrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 370
