주요 콘텐츠로 건너뛰기
Samsung Galaxy의 10번째 주력 핸드폰은 2019년 2월에 출시된 작고 경제적인 버전입니다. Android 9.0 (Pie)와 함께 제공됩니다.
51 질문 전체 보기
Hand Sanitizer got inside Galaxy S10e
The camera glass on my S10e shattered, and last night, hand sanitizer seeped in through there. My phone then suddenly heated up and the flashlight turned on and off by itself. I turned it off and mins later, I took out the motherboard and left it overnight in 90% rubbing alcohol. I put it back in the phone and reconnected everything, and it won’t turn on.
In case you’re wondering, here’s the contents of the hand sanitizer if it well help at all: 70% Ethyl alcohol, inactive ingredients: Water Glycerin, Propylene Glycol, carbomer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi @assbeater420 ,
Disconnecting or removing the battery as soon as possible was a good first step but it seems that you will have to open it up again and check for any damage to the components or if there is still evidence of corrosion occurring.
Look especially under any shields that may be covering some components as there may be corrosion occurring there.
The sanitizer would cause corrosion and provide circuit paths for the electricity (when the battery was still connected) which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
There could also be a galvanic reaction between the metals in the phone and those contained in the liquid which causes corrosion so you would need to ensure that the phone is absolutely clean and dry.
Using a soft brush along with the 90% Isopropyl Alcohol (just verifying that it is Isopropyl Alcohol 90% in the rubbing alcohol?) to brush it clean may be necessary. Isopropyl Alcohol is preferred as it completely evaporates and leaves no conductive residues whereas other forms of alcohol can leave residues which may be conductive.
The video in this link may be of some help. Look at about 21:15 into the video to see what corrosion can look like.
Make sure that it is completely dry before connecting the battery or the power to the phone, as even IPA will conduct if it is still wet.
Not that you may need it but here’s the ifixit Samsung Galaxy S10e guides as well
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Oneechan69 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 262
