주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixelbook Go는 Google의 프리미엄 크롬북으로, 미니멀한 디자인과 내구성이 뛰어난 마그네슘 클램쉘 외관이 특징입니다. 2019년에 출시되었습니다. 모델 번호: GA00521-US.
Re-insert clamshell pin into hinge
이미지
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
의 공유
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
의 공유
댓글 달기
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@piotrkaminsk163 How did you replace it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aaron Hoffer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 30
전체 시간: 1,629
