주요 콘텐츠로 건너뛰기
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
74 질문 전체 보기
I need to put my speaker on when calling
I have a Fairphone 2. it still works quite okay, I only have the issue that the one receiving my phone call doesn’t hear my voice unless I put the speaker on which means that I don’t have any privacy anymore as everything we talk about is loud and clear for everybody :(. What do I have to replace in order to solve that problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi,
First use a strong light and a magnifying glass and check if you can see if the voice inlet hole on the bottom edge of the phone appears to be blocked at all. If it is or if you’re not quite sure, do not use a pin or probe to try and clear it as you may damage components in the phone. Try using a vacuum cleaner to suck out any obstruction.
If you still cannot be heard on a call, most probably there is a problem with the primary microphone
Here is a link to the ifixit Fairphone 2 Microphone Module Replacement guide that will help.
There is also an app available on the phone that allows you to test the primary microphone as well as a lot of the other hardware in the phone which may also help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Rina Teeuwen-van der Ende 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 202
