주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
사용자 중심의 15인치 Asus F553M 노트북입니다. 2015년에 출시되었습니다.
Why won't my computer start properly?
I have an ASUS TUF 505dt laptop and when attempting to turn it on, the keyboard lights turn on, the power button light turns on, and the indictor lights work properly. No fans or other components the normally make noise are turning on. It stays completely silent. The screen also remains completely off. No dim light and an external monitor remains black also. I tested the battery and charger with the static test and they are working properly. I also tested the ram with a different laptop and the ram works. I also took out the circle motherboard battery for about 15-20 minutes and put it back in. That also didn't work. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If your system is able to power on and is not giving you any error messages, the issue may be with your hard drive. Try entering your PC's BIOS. Make sure that your hard drive is recognized by the system. Also, check your system's boot order and make sure that your hard drive is set to boot first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Coop 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 516
