주요 콘텐츠로 건너뛰기
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 질문 전체 보기
PS4 Gold Headset 2nd gen battery replacement/upgrade?
Hi, I have 2nd generation PS4 gold headset - and battery life isn’'t great anymore - is there a way to change it to new or upgrade it to higher capacity? Any advise will be appreaciated. This is the one I have:
https://uk.pcmag.com/headphones/93785/so...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Well, yes - figured it out by watching previous generation dissasembly - Battery is located on right side of the headset, so you need to take apart only that one. Then - carefully peel of long sticker going all the way around headphones. If you don’'t want to do - you can just cut through as you can feel placement of the screws through the sticker. There is 3 small philips (normal star) screws - unscrew them and the upper part comes easily of exposing battery - replace battery, put everything back as it was and all done. When putting things together - pay attention to the screw location - you can’'t put it back wrong (unless forcing). On cushon part - look for small arc on the cushon frame which needs to correspond with the hightened ‘‘rail’’ on the main base and then gently click it all together. No excessive force was needed at any point - everything came apart easily.
Just to confirm - as picture here doesn’'t have correct headset. This is the one I am using: Gold Wireless Headset for PS4 and PS VR (2nd generation) 2018
https://www.playstation.com/en-gb/access...
I used this battery: LIP1859 1800mAh - Maximum charge currency:0.4A, Maximum charge voltage:4.2V, Dimension: approx.6x4cm/2.4x1.6”, Weight: approx. 70g
For comparison - Original battery is LIP1472 570mAh; Maximum charge current 0.7A, Maximum charge voltage 4.2V, Dimension: approx.6x4cm/2.4x1.6”
So you are theorethically getting 3 times longer battery life. Still need to see how long it will work in the real life.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
@zakitc Karlis, thank you for the detailed explanation! I ordered wrong battery and your information helped! :)
Just another note to add. When removing the earcups, don't try and twist them off, this is only for the Gen 1. Just gently prise off the ear cups on the Gen 2
Note the Gen 1 is 3.7V, not 4.2. you can tell Gen 1 because earpieces twist off - much simpler - no tape.
댓글 달기
Hi @zakitc
Here’s a link that may be of some help
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Karlis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 2,549
