주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
Earpiece Not Working But proximity sensor does
I have a problem with my Iphone x. Basically the earpiece is not working but the proximity sensor and face id work normally.
Is there a way to fix the earpiece whithout changing the whole flex cable causing the face id not to work?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
As stated in the earpiece repair guide:
This assembly is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement.
The flood illuminator forms part of the biometric Face ID security feature, and Face ID functions will fail if the original component is damaged or incorrectly installed. Replacing it with a new part will also cause Face ID to fail, so take extra care not to damage any of these components during this procedure. If damaged, only Apple can restore Face ID function.
So this means if you replace the front sensor/earpiece assembly with the flex cable you’ll lose Face ID. It is possible to replace the speaker alone, but this requires high level of soldering skill as can be seen in this video of NorthridgeFix: https://www.youtube.com/watch?v=qo-tOq8y...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Oh okay, thanks I'll maybe try it
Good luck with the repair! And thanks for accepting my answer :)
댓글 달기
답변을 추가하세요
Nova Class 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 134
