Why is it keep entering to system information?
Everytime i switch on it keeps on entering to system information and can't exit even hitting esc key to exit..
좋은 질문 입니까?
좋은 질문 입니까?
Yes, that does sound like your BIOS. It appears as if you have lost either your hard drive or the operating system on your hard drive. Take a look at the setup utility, the manual is here http://h10032.www1.hp.com/ctg/Manual/c01... and you access the setup by turning on or restarting the computer. While the “Press the ESC key for Startup Menu” message is displayed in the lower-left corner of the screen, press f10. It should show your hard drive in the setup. If it does NOT show it, my guess would be that it is your drive that has failed. If it does show up, then you are having issues with your operating system not being recognized. On some selected models, you can try and recover from a partition on the HDD. You get there by " pressing either the Start button or f11. This restores the computer to its factory condition.
To restore the system from the partition, follow these steps:
1. Access Recovery Manager in either of the following ways:
● Select Start > All Programs > Recovery Manager > Recovery Manager.
– or –
● Turn on or restart the computer, and then press esc while the “Press the ESC key for Startup
Menu” message is displayed at the bottom of the screen. Then, press f11 while the “Press
<F11> for recovery” message is displayed on the screen.
2. Click System Recovery in the Recovery Manager window.
3. Follow the on-screen instructions."
That manual is available at http://h10032.www1.hp.com/ctg/Manual/c01... Hope this will help you a bit. Good Luck.
해당 답변은 도움이 되었습니까?
I have pressed all the keys but the system information menu is not going off
There is nothing wrong with my system apart from the press escape issue so unfortunately this does not fix it for me.
24 시간 전: 8
7일 전: 31
30일 전: 114
전체 시간: 22,123
댓글 6개
What system information are you referring to? Is it your BIOS stuff that comes up....? Does it enter the OS or does it hang up right after it displays the information about your system?
oldturkey03 의
after showing the HP Logo it automatically goes to system information menu... i think it a bios stuff.. What will i do? please help! Thank you and God Bless...
Alex Neameyer 의
It says notebook model
Product number
Serial number
Born on date
System board I'd
Product configuration
System board CT number
Bios version
Processer type
Processer speed
Total memory
Primary battery sn
Wlan FCC ID
Press <esc> to continue
(I press esc but nothing happens) (this screen pops up as soon as I turn on my computer)
John Raito 의
Same thing happening to my HP ..
BRIAN ATEGEKA 의
Same thing here, I have to press the esc key before it will boot windows.
Keith Ward 의
댓글 1개 더보기
